Units
convert to/from common unit sets.
It is often necessary to convert data when comparing disparate sources (for example test vs CAE). This menu provides a simple and fast way to convert one or many data curves simultaneously. All conversion constants are displayed for you to review before applying the conversion.
The Units menu contains the following secondary menus. From each menu, you can convert various units of measure.
Time
- Macro
 - Function
 - ms >> sec/min/hour
 - Converts milliseconds to: seconds, minutes and hours.
 - sec >> ms/min/hour
 - Converts seconds to: milliseconds, minutes, and hours.
 - min >> ms/sec/hour
 - Converts minutes to: milliseconds, seconds, and hours.
 - hour >> ms/sec/min
 - Converts hours to: milliseconds, seconds, and minutes.
Distance English
- Macro
 - Function
 - inch >> mm/cm/meter/ft/mile
 - Converts inches to: millimeters, centimeters, meters, feet, and miles.
 - ft >> mm/cm/meter/inch/mile
 - Converts feet to: millimeters, centimeters, meters, inches, and miles.
 - mile >> mm/cm/meter/inch/ft
 - Converts miles to: millimeters, centimeters, meters, inches, and feet.
Distance Metric
- Macro
 - Function
 - mm >> cm/meter/inch/ft/mile
 - Converts millimeters to: centimeters, meters, inches, feet, and miles.
 - cm >> mm/meter/inch/ft/mile
 - Converts centimeters to: millimeters, meters, inches, feet, and miles.
 - meter >> mm/cm/inch/ft/mile
 - Converts meters to: millimeters, centimeters, inches, feet, and miles.
Velocity
- Macro
 - Function
 - ft/s >> mph, kmh, m/s
 - Converts feet per second to: miles per hour, kilometers per hour, or meters per second.
 - mph >> ft/s, kmh, m/s
 - Converts miles per hour to: feet per second, kilometers per hour, or meters per second.
 - m/s >> ft/s, mph, kmh
 - Converts meters per second to: feet per second, miles per hour, or kilometers per hour.
 - kmh >> ft/s, mph, m/s
 - Converts kilometers per hour to: feet per second, miles per hour, or meters per second.
Acceleration
- Macro
 - Function
 - ft/s/s >> g
 - ft/s/s >> m/s/s
 - Converts feet per second per second to g's.
 - g >> ft/s/s
 - g >> m/s/s
 - Converts g's to feet per second per second.
 - m/s/s >> g
 - m/s/s >> ft/s/s
 - Converts meters per second per second to g's.
Energy/Moment
- Macro
 - Function
 - N*m (Joule) >> inch*Ibf, ft*Ibf, BTU
 - Converts Joules to: inches times pound force, feet times pound force, or British Thermal Units.
 - inch*Ibf >> N*m, ft*Ibf, BTU
 - Converts inches times pound force to: Joules, feet times pound force, or British Thermal Units.
 - ft*Ibf >> N*m, inch*Ibf, BTU
 - Converts feet times pound force to: Joules, inches times pound force, or British Thermal Units.
 - BTU >> N*m, inch*Ibf, ft*Ibf
 - Converts British Thermal Units to: Joules, inches times pound force, feet times pound force.
Force/Press
- Macro
 - Function
 - N/m/m (Pascal) >> psi, bar, atm
 - Converts Newtons to pounds per square inch, barometric pressure, or atmospheric pressure.
 - psi >> N/m/m, bar, atm
 - Converts pounds per square inch to Newtons, barometric pressure, or atmospheric pressure.
 - bar >> psi, N/m/m, atm
 - Converts barometric pressure to pounds per square inch, Newtons, or atmoshperic pressure.
 - atm >> psi, bar, N/m/m
 - Converts atmospheric pressure to pounds per square inch, barometric pressure, or Newtons.
