Math
Allows you to perform basic math operations on one, two, or three curves at a time.
The operations include curve addition and multiplication and resultants, for example. The start, end, or sample frequency of the various curves is not an issue - the VST automatically crops and samples the input curves as needed. The curves must be using the same units, in most cases.
The Math menu contains three secondary menus: one curve, two curves, and three curves. Those secondary menus contain the following plot macros:
One Curve
- Absolute
 - Given c1, a curve is created which is the absolute value of y vs. x.
 - Acoustic Weighting
 - Auto Correlation
 - If you are comparing two curves, this function would show where the curves match in phase, where c1 and c2 are the same curve.
 - Derivative
 - Given c1, a curve is created that is the derivative of c1.
 - Double Integral
 - Given c1, a curve is created that is the double integral of c1.
 - Double Derivative
 - Duration
 - Calculates the load versus duration for a given curve.
 - Duration Comp
 - Partitions the input curve into 101 bins, reporting only the negative curve values.
 - Duration Tens
 - Partitions the input curve into 101 bins, reporting only on the positive curve values.
 - Integral
 - Given c1, calculates the integral of the c1.
 - Max Note
 - Min Note
 - Normalize
 - Given c1, calculates a new curve, such that the peak value is "1".
 - Normalize over Max
 - Resample or Sample Points
 - Resamples the given input curve to the specified data frequency.
 - Reverse Curve
 - Reverses a curve about the vertical axis, like a mirror.
 - Square
 - Calculates the square of the curve.
 - Window
 - Crops the curve to the given window size.
 - Window Integral
 - Given c1, calculates the integral of c1 over the range of the window.
 - Zero
 - Sets the y value in a given range to the user-defined constant.
 - g>>mph
 - Integrates acceleration curve to obtain velocity.
 - g>>inch
 - Double integrates an acceleration curve (given in g’s and seconds) to a displacement (given in inches and seconds).
 - mph>>g
 - Given c1, a curve is created that is the derivative of velocity to acceleration, while converting MPH to g's.
Two Curves
- Add
 - Adds two curves.
 - Average
 - Averages two curves.
 - Cross Correlation
 - Given c1 and c2, a curve is created which is the cross correlation between the y vectors of c1 and c2.
 - Cross Plot
 - Given c1 and c2, this function plots c1.y as x and c2.y as y of a new curve.
 - Divide
 - Divides two curves. If c2 has zero values, this will fail.
 - Divide with Zero
 - If c1 is divided by c2, and if c2 has any zero values, then c1/c2 equals 0.
 - Multiply
 - Multiplies two curves.
 - Resultant
 - Given c1 and c2, calculates the square root of (c12 + c22).
 - Subtract
 - Subtracts two curves.
Three Curves
- Add
 - Adds three curves.
 - Average
 - Averages three curves.
 - Multiply
 - Multiplies three curves.
 - Resultant
 - Given c1, c2, and c3, calculates the square root of (c12 + c22+c32).
