Dummy Positioning
Position a dummy model using the Dummy Browser.
Dummy Browser
Overview of the Dummy Browser.
This browser is compatible with all LS-DYNA and Radioss Humanetics dummies (encrypted or not encrypted) and also with LSTC dummies.
You can undo and redo actions made in the browser using the Undo and Redo commands on the Restore toolbar.
| Column | Description |
| Entity | List of the dummies and dummy bodies. |
| ID | Displays the dummies and bodies IDs. |
| Color | Displays the body entity colors. Body color is different from the component color defined in the Model Browser. The body color is activated when a body is in Review mode or when display mode is set on “By Body”.  |
Entity Editor
The Entity Editor is used to assign, modify and quickly view the attributes defined inside Dummy Browser entities.
Figure 3.
Figure 4.
The Entity Editor is also used to modify the position of bodies. You can directly define the angle of rotation to apply in each axis of rotations in which the selected body is able to move.
Figure 5.
Context Menu
Supported Entities
The Dummy (
) is the root of the
                hierarchy in the Dummy Browser. A dummy is defined by bodies
) representing the
                different kinematic assemblies of the dummy.
Position Dummies
Position the Body Manually
Position the Body Automatically
Contact Detection with Surrounding Components
Auto-contact detection allows you to automatically detect contact between dummy limbs and surrounding structural components during the positioning process. Limb motion is automatically stopped on contact detection.
Position Dummies with Test-Lab Data
Automatically position a FE Dummy model based on test-lab coordinates measurements data.
Setup Pre-Simulation
Export an input deck to simulate the deformation of the dummy.
Figure 10.
The method used for the pre-simulation is known as the “cable” method, which uses 1D elements connected to dummy bodies, in order to pull them from their initial position to their final position.
All “cables” are automatically created on each dummy body and all boundary conditions needed for the pre-simulation.
The simulation result files can be imported to update the initial FE model and thus remove the intersections and penetrations between the dummy components.
- Only Dummy: Export the solver files to perform the simulation of the dummy deformation only.
 - Dummy with Seat: Export the solver files to perform the simulation of the dummy and the seat deformation in one step.
Only Dummy
- In the Dummy Browser, right-click on the dummy and select from the context menu.
                In the PreSimulation Tool dialog, define settings
                    accordingly.
 - Define PreSimulation Tool Options accordingly.
 - Click Export.
Dummy with Seat
Overview of supported options in the PreSimulation Tool.
LS-DYNA
- Simulation Parameter
- Simulation Time
 - Define the total simulation time in *CONTROL_TERMINATION for the pre-simulation.
 - Time Step
 - Define the control time step value in *CONTROL_TIMESTEP for the pre-simulation.
 - Force in cables (valid for the Force Based option only)
 - Define the pre-tension force to be applied on the cable elements in *MAT_CABLE_DISCRETE_BEAM.
 - Force ramp up time (valid for the Force Based option only)
 - Define the ramp-up time for the pre-tension force in *MAT_CABLE_DISCRETE_BEAM.
 - Damping on cables (valid for the Force Based option only)
 - Define the damping value on the discrete elements in *MAT_DAMPER_VISCOUD.
 - Global damping value
 - Define the system damping constant in *DAMPING_GLOBAL.
 - Initial Stress Results
- Import *INITIAL_STRESS_SOLID
 - Import the initial stresses for solid elements from the .dynain file.
 - Import *INITIAL_STRESS_SHELL
 - Import the initial stresses for shell elements from the .dynain file.
 - Import *INITIAL_STRESS_BEAM
 - Import the initial stresses for beam elements from the .dynain file.
Radioss
- Simulation Parameters
- Generate XREF for initial stresses
 - Create /XREF cards for the dummy components which are compatible with this RADIOSS feature in terms of material type and element formulation. The XREF cards are generated within the original session during the export of the pre-simulation deck, and not during import of .h3d file.
 - Simulation time
 - Define the total simulation time in /RUN card for the pre-simulation.
 - Time Step
 - Define the control time step value in /DT/NODA/CST card for the pre-simulation.
 - Define the system damping constant in /DAMP card.
 - Create rigids for end bodies
 - Automatically rigidify the end bodies (feet, hands, head) of the dummy during the pre-simulation.
