Graph Parameters
Select the Y-Type, Y-Request and Y-Component.
- Head Impactor
 - If Head Impactor is selected, the tool asks for the Y-type, Y-request, and Y-component of the first location for both the Displacement vs Time graph and the Acceleration vs Time graph. From the next point forward, it looks for same Y-Type, Y-request, and Y-component. If the same Y-Type is present but Y-request is not available, then the tool checks if there is only one Y-request. If more than one Y-request is present, you need to input the Y-request for the respective point.
 - Upper Leg Impactor
 - If Upper Leg Impactor is selected, the dialog is displayed twice to select the Y-Type, Y-Request and Y-Component: first to plot the Resultant Force vs Time and then to plot the Bending Moment vs Time graphs.
 - Lower Leg Impactor
 - If Lower Leg Impactor is selected, the dialog is displayed three times to select the Y-Type, Y-Request and Y-Component for the Knee Bending Angle vs Time, Knee Shear Displacement vs Time and the Upper Tibia Acceleration vs Time graphs.
