Attach a Note to a Curve
- From the Notes panel, create a new note by clicking Add under the Note list.
Or
- Select a note from the list or pick one from the window.
 - Click the Attach To tab.
 - Select Curve as the attachment.
 - Pick a point on a curve.
Or
- Use the Find point controls to position the note leader on a curve.
                For complex plots only, select Attach to real or
                        Attach to imaginary.
                The note is displayed with a leader pointing to the curve.
 - Or, select Place note on curve point to display the note directly at the curve point.
