Add a Note
                From the Notes panel, click Add under the Note
                    list.
                A note labeled Note1 is appended to the list.
                Select the new note from the list and enter a note name in the field above the
                    list and press Enter.
                The new note is now displayed in the list using the new name.
 - Enter note text in the text box.
 - Click Apply.
 - Select an alignment.
                Select an attachment method.
                The new note is now displayed in the window.
