Position a Datum Plane
                From the HyperGraph 3D toolbar, click the Datum
                    Planes icon,
             - From the Datum Planes panel, select a datum plane from the Datum list or from the screen.
 - Select the Position tab.
                Under Method:, set the orientation method:
- Vertical along the Z axis
 - Horizontal along the X axis
 - Horizontal along the Y axis
 - Three points
 - Under Orientation:, select points on the curve to define the orientation.
 - Select a base point or enter XYZ values to define the location.
 - Click Apply.
