Generate an XY Plot from the Datum Plane's Intersection
                From the HyperGraph 3D toolbar, click the Datum
                    Planes icon,
             - Select a datum plane from the Datum list.
 - Select Cross section or Clipping plane.
 - Select the Create XY Plot tab.
                Under Place curve on:, select Preview plot,
                        New plot, or Existing
                    plot.
- Preview plot
 - Creates the curve in a pop-up window.
 - New plot
 - Creates the curve in a new plot window.
 - Existing plot
 - Creates the curve in an existing plot window.
 - If you select Existing plot, select an existing plot window from the tree selection.
 - Click Apply to create the plot.
