Rattle Evaluation
The automatic assessment allows the understanding of the rattle phenomena using the following:
- Relative Displacement (X, Y, Z, MAG)
 - Relative movement between the two components along the Evaluation lines.
                        This is available in all directions:
- Z defines the gap direction
 - X-Y defines the contact plane
 - Dynamic Tolerance
 - Upfront risk or no risk where the relative displacement is compared to the actual Gap and tolerance values.
 - Contact Risk Index
 - If there are risks for the rattle, these can be further quantified using CRI based on the stiffness of the interface. A soft interface has a lower risk for an audible Rattle than a hard interface.
