Post Processing Options
- Model File
 - Select the OptiStruct solver file (.fem) exported from Export OptiStruct Solver File.
 - Pre-Output File
 - Select the pre output CSV file.
 - Results File(s)
: Select and add a
                            results file for post processing.- Subcase Selection
 - All subcases in the selected results file are listed in the table.
 - Save Session File
 - Name the session file and select a destination folder.
 - Post Processing
- Analysis Type
- Rattle & Squeak
 - Analyze all the lines in the model.
 - Rattle
 - Analyze only the rattle lines.
 - Squeak
 - Analyze only the squeak lines.
 - Lines to analyze
 - Select All or only the required E-Line to analyze.
 - % statistical evaluation
 - Specify the percentage of statistical evaluation based on the methodology implemented for studying the squeak and rattle analysis.
 - Session Type
- Summary
 - Creates one session per subcase with only the overview pages for each of the squeak and rattle interface in the model.
 - Full Analysis
 - Creates one session per subcase, along with detailed plots for each of the interfaces present in the model.
: Delete a results file
                            from the session.
