Use the Combined Loadings tab to review and analyze the effects of Dynamic and Static
        loads on the gap and relative displacement.
        Important: The Combined Loadings tab is only activate when dynamic and
                static loadcases are identified in the imported model file.
See Combined Loadings for more
            information.
                If necessary, open the SNRD-Post Browser.
                In the SNRD-Post Browser, select the Combined Loadings
                    tab.
                Select a loadstep from Loading type 1 list.
                Select a static loadstep from Loading type 2 list.
                Enter Scale factor values.
- Optional:
                Select the Affects gap check box.
                Select the required E-Line or All from E-Line(s)
                    Selection list.
                Select the required analysis type from Session Type.
                Click Combine Results.
        The combined effect of the selected
            loadsteps on the E-Lines is evaluated and the results are plotted,
            relative displacement and histograms.
