Loadcase Setup
Setup loadcases to solve and extract results.
Technology and problem evaluation approaches used in SnRD.
Explore the SnRD Pre-Processing user interface.
Use the tools in the Setup Group to setup evaluation lines and define loadcases.
Import all data required for the squeak and rattle analysis preparation.
Use the Define Interface tool to create, import, and edit geometric lines along the interfaces to evaluate.
Use the Create E-Lines tool to create evaluation lines at component interfaces.
Use the Manage E-Line tool to review and manage E-Lines.
Use the Dynamic Event tool to define a dynamic (Modal Transient (MTRAN)) loadcase to solver and analyze squeak and rattle occurrences.
Use the Static Event tool to define a static (linear static) loadcase to solve and understand squeak and rattle occurrences.
Use the Thermal Event tool to define a temperature or thermal loadcase to solver and understand squeak and rattle occurrences.
Create Single Point Constraints (SPCs).
Use a variability study to examine how squeak and rattle risks are affected by manufacturing variations.
Use the Manage E-Points tool to modify local system collectors and evaluation points.
Evaluate loadcase and export solver deck.
Launch and explore SnRD Post Processing.
Use of Altair Ziegler SnRD Material Database.
ON THIS PAGE
ON THIS PAGE
