hwIPage RemoveWindowSyncGroup
Removes a window synchronization group.
hwIPage_handle RemoveWindowSyncGroup syncGroupName
Tcl Modify
This command removes a window synchronization group.
- syncGroupName
 - The name of the window synchronization group you would like to remove.
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle pg [proj GetActivePage]
set numberOfWindows [pg GetNumberOfWindows]
set windowIdList ""
for { set i 1} { $i <= $numberOfWindows } { incr i } {
    lappend windowIdList $i
if { [string length $windowIdList] } {
    set syncGroupName "MyWindowSyncGroup"
    pg AddWindowSyncGroup $syncGroupName $windowIdList
    pgr SetWindowSyncGroupState $syncGroupName true; #activate window synchronization on this group
    puts "Current state  of $syncGroupName : [pg GetWindowSyncGroupState $syncGroupName]"
    pg RemoveWindowSyncGroup $syncGroupName
hwi CloseStackErrors
This command returns a warning code if a synchronization group with the specified name does not exist.
