API, Reference Guides
2023
  1. Home
  2. API, Reference Guides
  3. Tcl/Tk Commands
  4. Tcl/Tk Commands
  5. HyperGraph 3D
  • What's New
  • Get Started
  • Tutorials
  • API, Reference Guides
Index
2023
  • What's New
  • Get Started
  • Tutorials
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
      • Program with APIs for Beginners
      • Object Hierarchy
      • Tcl/Tk Classes
      • Script Use Cases
      • Tcl/Tk Example
      • Program with Tcl/Tk Command Tutorials
      • Tcl/Tk Commands
        • Framework
        • MotionView
        • HyperView
        • HyperGraph 2D
        • HyperGraph 3D
          • plt3DIAxis Class
          • plt3DIBarChart Class
          • plt3DIChart Class
          • plt3DICursor Class
          • plt3DICurve Class
          • plt3DICurveGroup Class
          • plt3DILegend Class
          • plt3DINote Class
          • plt3DIParametric Class
          • plt3DIPlane Class
          • plt3DIPlot Class
          • plt3DISurface Class
          • plt3DIWaterfall Class
        • MediaView
        • TextView
        • HgTrans
        • TableView
        • Postquery Commands
        • Context Commands
        • Framework Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • HyperMesh
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
2023
  1. Home
  3. Tcl/Tk Commands
  4. Tcl/Tk Commands
  5. HyperGraph 3D
  • What's New
  • Get Started
  • Tutorials
Index
HyperGraph 3D
  • plt3DIAxis Class
  • plt3DIChart Class
  • plt3DICurve Class
  • plt3DINote Class
  • plt3DIPlane Class
  • plt3DIPlot Class
