Clears the default preference file.
Returns a list of component information for the default preference file.
Finds the number of preference files currently in the preference file list (not including the default preference file).
Reads and loads a script file from within the list of preference files.
Adds the preference file to the internal list of preference files.
Sets a preference file as the default preference file.
Removes a file from the internal list of preference files.
ON THIS PAGE
ON THIS PAGE
