hwI3DViewCtrl GetOrientation
Finds the orientation of the plot.
hwI3DViewControl_handle GetOrientation
Tcl Modify
This command gets the orientation (positioning) of the 3D plot, outputting six numbers: the first three numbers are the translation of the 3D plot from the origin of x, y, and z, and the last three numbers are the three Euler angles representing the rotation about the Z, X, and Z axes, respectively.
hwi OpenStack;
hwi GetSessionHandle sess;
sess GetProjectHandle proj;
proj GetPageHandle p1 1;
p1 GetWindowHandle w1 1;
w1 GetViewControlHandle vc
vc GetOrientation
      Error
Returns success (the orientation) or an error message.
Keywords
3D plot
Tcl
Modify
