HMIN_element_writebar3_ynode()
Writes a 3-noded bar element to HyperMesh using a node to define the local bar y axis.
void HMIN_element_writebar_ynode(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype node, double offseta[3], double offsetb[3], int pinsa, int pinsb, HM_entityidtype nodes[], HM_entityidtype collectorid);
HyperMesh hminlib Function
- id
 - The ID of the element.
 - elementtype
 - The type of the element, a user-defined value.
 - propertyid
 - The ID of the property to which the bar element should point.
 - node
 - The node that lies on the beam local y axis.
 - offseta[3]
 - The amount to offset the bar at end a.
 - offsetb[3]
 - The amount to offset the bar at end b.
 - pinsa
 - The degrees of freedom assigned to end a.
 - pinsb
 - The degrees of freedom assigned to end b.
 - nodes[3]
 - The nodes associated with the element.
 - collectorid
 - The ID of the collector where the bar element should be placed.
None.
