API, Reference Guides
2023
  1. Home
  2. API, Reference Guides
  3. HyperMesh
  4. FE Input Readers
  5. Commands and Functions
  • What's New
  • Get Started
  • Tutorials
  • API, Reference Guides
Index
2023
  • What's New
  • Get Started
  • Tutorials
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • HyperMesh
      • API Programmer's Guides
      • Data Names
      • Ext API
      • FE Input Readers
        • Result Readers
        • hmlib
          hmlib is a library which contains a set of routines to aid you in writing a C program.
        • hminlib
          hminlib is a set of routines which allows you to write an external input translator.
        • hmmodlib
          hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
        • hmreslib
        • Create FE Input Readers
        • Commands and Functions
          • hmlib Functions
          • hminlib Functions
          • hmmodlib Functions
          • hmreslib Functions
      • HMASCII
      • Scripts
        This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
      • Solver Templates
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
2023
  1. Home
  3. HyperMesh
  4. FE Input Readers
  • What's New
  • Get Started
  • Tutorials
Index
  • hmlib Functions
  • hminlib Functions
