API, Reference Guides
2023
  1. Home
  2. API, Reference Guides
  3. HyperMesh
  4. FE Input Readers
  5. Commands and Functions
  6. hminlib Functions
  7. Transfer Functions
  8. connectors
  • What's New
  • Get Started
  • Tutorials
  • API, Reference Guides
Index
2023
  • What's New
  • Get Started
  • Tutorials
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • HyperMesh
      • API Programmer's Guides
      • Data Names
      • Ext API
      • FE Input Readers
        • Result Readers
        • hmlib
          hmlib is a library which contains a set of routines to aid you in writing a C program.
        • hminlib
          hminlib is a set of routines which allows you to write an external input translator.
        • hmmodlib
          hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
        • hmreslib
        • Create FE Input Readers
        • Commands and Functions
          • hmlib Functions
          • hminlib Functions
            • Basic Functions
            • File Locator Functions
            • ID Functions
            • Message Functions
            • Move Functions
            • Rename Functions
            • Transfer Functions
              • assemblies
              • attributes
              • bags
              • blocks
              • cards
              • components
              • connectors
                • HMIN_CE_CreateDefined()
              • contactsurfs
              • controlvols
              • curves
              • dequations
              • designvars
              • desvarlinks
              • dictionaries
              • dvprels
              • elements
              • ellipsoids
              • equations
              • groups
              • laminates
              • lines
              • loadcols
              • loads
              • loadsteps
              • materials
              • mbjoints
              • mbplanes
              • metadata
              • miscellaneous
              • multibodies
              • nodes
              • objectives
              • opticonstraints
              • opticontrols
              • optidscreens
              • optiresponses
              • outputblocks
              • plies
              • plots
              • properties
              • sensors
              • sets
              • surfaces
              • systemcols
              • systems
              • tables
              • tags
              • titles
              • vectorcols
              • vectors
              • Deprecated hminlib Functions
                The list of deprecated hminlib functions, and the new functions to use.
              • Undocumented hminlib Functions
                The list of undocumented hminlib functions.
          • hmmodlib Functions
          • hmreslib Functions
      • HMASCII
      • Scripts
        This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
      • Solver Templates
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
2023
  1. Home
  3. HyperMesh
  4. FE Input Readers
  8. connectors
  • What's New
  • Get Started
  • Tutorials
Index
connectors
