pyramid5
Unless otherwise specified, data names are accessible in level 3 only.
- aspect
 - The element aspect ratio.
 - attributesmax
 - The number of attributes owned by this entity.
 - centerx
 - The x coordinate of the element centroid.
 - centery
 - The y coordinate of the element centroid.
 - centerz
 - The z coordinate of the element centroid.
 - collector
 - Pointer to the collector that owns the element.
 - config
 - The configuration of the entity.
 - definedentity
 - True if the entity is defined, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - jacobian
 - The element jacobian.
 - largestfacearea
 - The area of the largest element face.
 - longestside
 - The longest element edge length.
 - maxangle
 - The maximum interior angle.
 - minangle
 - The minimum interior angle.
 - moduleid
 - The module ID of the entity.
 - node1 - node5
 - Pointers to the element nodes.
 - nodecount
 - The number of nodes for the element. Valid for hm_getvalue query only.
 - nodes
 - The list of nodes for the element. Valid for hm_getvalue query only.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - property
 - Pointer to the property assigned to the entity.
 - propertyid
 - The ID of the property assigned to the entity.
 - propertyidflag
 - 1 if a property is assigned directly to the entity, 0 otherwise.
 - shortestside
 - The shortest element edge length.
 - skew
 - The element skew angle.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
 - type
 - The solver dependent type code for the entity.
 - typename
 - The solver dependent type name for the entity.
 - volume
 - The volume of the element.
 - warpage
 - The element warpage.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
