API, Reference Guides
2023
  1. Home
  2. API, Reference Guides
  3. HyperMesh
  4. Data Names
  5. loads
  • What's New
  • Get Started
  • Tutorials
  • API, Reference Guides
Index
2023
  • What's New
  • Get Started
  • Tutorials
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
    • Translators
    • Result Math
    • HWC Console
    • HyperMesh Report
    • HyperMesh
      • API Programmer's Guides
      • Data Names
        • accelerometers
        • alefsiprojections
        • alereferencesystemcurves
        • alereferencesystemgroups
        • alereferencesystemnodes
        • alereferencesystemswitches
        • alesmoothings
        • aletanktests
        • analysis
        • analysisparameters
        • assemblies
        • attachmentcontrols
        • attachments
        • axisymmetries
        • bags
        • beamsectcols
        • beamsects
        • behaviors
        • blocks
        • bodies
        • boxes
        • cards
        • charts
        • clearances
        • collections
        • collisions
        • comments
        • components
        • configurations
        • connectorgroups
        • connectors
        • connectorsets
        • constrainedextranodes
        • constrainedrigidbodies
        • constraints
        • contactbehaviors
        • contactgroups
        • contactsurfs
        • controlvols
        • crosssections
        • curves
        • dampings
        • ddvals
        • dequations
        • designpointmethods
        • designpoints
        • designpointsets
        • designvars
        • desvarlinks
        • directmatrixinputs
        • dobjrefs
        • domains
        • dvprels
        • elementbehaviors
        • elementclusters
        • elements
        • ellipsoids
        • encryptions
        • enginefiles
        • equations
        • explorations
        • failures
        • features
        • fields
        • freebodygroups
        • freebodysections
        • frequencies
        • frequencysets
        • frictions
        • geometricrepresentations
        • global
        • groups
        • handles
        • hourglass
        • includefiles
        • integrationrules
        • interfacecomponents
        • interfacelinkings
        • internalsupports
        • initialstates
        • joints
        • laminates
        • legends
        • lines
        • lists
        • loadcols
        • loads
          • accelerations
          • constraints
          • fluxes
          • forces
          • moments
          • pressures
          • temperatures
          • velocities
        • loadsteps
        • materialbehaviors
        • materials
        • mbjoints
        • mbplanes
        • mechanismconstraints
        • mechanisms
        • memberjoints
        • memberpanels
        • members
        • membersections
        • membersegments
        • meshcontrols
        • metadata
        • modelcheckchecks
        • modelcheckcorrections
        • modules
        • morphconstraints
        • morphvolumes
        • multibodies
        • nctlayers
        • nodes
        • noisecontroltreatments
        • objectives
        • opticonstraints
        • opticontrols
        • optidscreens
        • optiresponses
        • outputblocks
        • outputrequests
        • panels
        • parameters
        • partsets
        • perturbations
        • physicalquantities
        • plies
        • plotcontrols
        • plots
        • points
        • polycages
        • positions
        • pretensioners
        • properties
        • referencegeometries
        • regions
        • responses
        • resources
        • results
        • resultsimulations
        • resultsubcases
        • retractors
        • rigidbodies
        • rigidwalls
        • scenarios
        • seamexcitations
        • seamjunctions
        • seamsubsystems
        • seasubsystems
        • seatbeltcontrolpointss
        • seatbelts
        • sections
        • sensors
        • sequences
        • sets
        • shape3ds
        • shapes
        • skeletons
        • sketches
        • sliprings
        • smartrules
        • solids
        • solvermasses
        • solversettings
        • solversubmodels
        • solverrepresentations
        • stateequations
        • structuralproperties
        • studies
        • subsystemconfigurations
        • subsystems
        • subsystemsets
        • surfaces
        • symmetries
        • symmetrypivots
        • systemcols
        • systems
        • tables
        • tags
        • terminations
        • timestepcontrols
        • titles
        • transformations
        • vectorcols
        • vectors
        • weldlines
      • Ext API
      • FE Input Readers
      • HMASCII
      • Scripts
        This section contains details on general HyperWorks scripting concepts, along with documentation on the Tcl commands that can be used to query and modify the database and GUI.
      • Solver Templates
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
2023
  1. Home
  3. HyperMesh
  4. Data Names
  5. loads
  • What's New
  • Get Started
  • Tutorials
Index
loads
  • accelerations
  • constraints
  • fluxes
  • forces
  • moments
  • pressures
  • temperatures
  • velocities
See Also
loadcols
