configurations
Unless otherwise specified, data names are accessible in level 3 only.
- activestate
 - Returns false if the entity is set inactive, true otherwise.
 - attributesmax
 - The number of attributes owned by this entity.
 - config
 - The configuration of the entity.
 - configuration_entities
 - The recursive list of children configuration entity IDs.
 - definedentity
 - True if the entity is defined, false otherwise.
 - id
 - The ID of the entity.
 - include
 - The ID of the include file the entity is organized in.
 - includeid
 - internalid
 - internalname
 - The internal name of the entity.
 - moduleid
 - The module ID of the entity.
 - name
 - The name of the entity.
 - outputsuppressed
 - Returns non-zero if the entity is set "do not export", 0 otherwise.
 - part_entities
 - The recursive list of children Part Assembly and Part IDs.
 - part_sets
 - The recursive list of children Part Set IDs.
 - poolid
 - The pool number of the entity.
 - poolname
 - The pool name of the entity.
 - solver_id
 - The solver ID of the entity.
 - solverkeyword
 - The name of the solver keyword.
 - solvername
 - The solver name of the entity for entities enabled for name pool, otherwise the internal name of the entity.
Version History
2020.1 - Added new data name solverkeyword.
2021.1 - Added new data names moduleid, poolid, poolname, and solver_id.
2021.2 - Added new data names internalname and solvername.
