*solversettings()
Starts a solversettings block.
*solversettings (config)
HyperMesh Template Command
Requires an *output() command at the end of the output block definition.
- config
 - An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out all solversettings with the format:
*solversettings(id,"name")
*solversettings()
  *format()
    *string("*solversettings(")
    *field(integer,id,0)
    *string(",")
    *field(quotedstring,name,0)
    *string(")")
    *end()
*output()
Incorrect usage results in an import error.
Version History
2021.2
