*counterset()
Sets the initial value of the global counter.
*counterset (counter, value)
HyperMesh Template Command
- counter
 - Value from counter1 to counter20 indicating the counter(s) to set to the next parameter.
 - value
 - Value of the counter.
Counters can be useful to specify continuation cards on some analysis codes. For an example, see theNastran template file in HyperMesh.
