*smartrules()
Starts a smartrules block.
*smartrules (config)
HyperMesh Template Command
This command must be accompanied by a *output() command at the end of the block.
- config
 - An integer that defines the config of entities in the block. If not specified, all entities are considered for the block.
To write out standard smartrules and their associated objects:
*smartrules()
                *format()
                *string("*smartrules(")
                *field(integer,id,0)
                *string(",")
                *field(quotedstring,name,0)
                *string(")")
                *end()
                *output()
Incorrect usage results in an import error.
Version History
2022.2
