Create new materials and define their properties.
The materials available and their corresponding properties are based on the fatigue
module that you select. If SN or Weld is selected, materials with SN properties are
listed. If EN is selected, materials with EN properties are listed.
Note: Unlike OptiStruct, materials in HyperLife are defined by stress amplitude by default.
Click the Material tool.
The Assign Material dialog opens.
Create a new material with reference to an existing material.
Click the Material DB tab.
Search the database for a material with properties that resemble your
desired material.
Tip: Use the search widgets to quickly find and filter
options.
Click Save as MyMaterial.
Click the My Material tab.
Edit the name of the newly created material and any relevant
properties.
Click Plot & Save.
Create a material from scratch.
Click
to create a new
material.
Edit the name and any relevant properties.
Note: Several input methods are available for fitting an SN curve based
on the data provided.
Click Plot & Save.
Note: Changing the units automatically updates the material properties and magnitudes
accordingly.
