Improvement of the test Characterization / Model / Maps for SMPM & RSM
Options have been added to compute and display maps with respect to the rotor position dependency.
In case the Rotor position dependency is set to “Yes”, computations are done in the Jd - Jq plane with an additional third axis corresponding to the rotor position θr.
D-axis dynamic inductance in Jd - Jq area Selection of rotor angular position (1) in the drop-down menu, the map is instantaneously updated (2) |
