Synchronous machines – Motor Factory – Export environment
Export LUT MAT - Error in FLUX_ID0 variable in thermal solving.
This issue occurs in the EXPORT / SYSTEM / LUT while exporting a MAT-PSIM-Activate format file with thermal solving (with several magnet temperatures).
One of the variables contained in the .mat file (FLUX_ID0) is only generated for the maximum magnet temperature.
In other words, if Tmag=[20, 100, 200], the values stored in FLUX_ID0 correspond to Tmag=200 but the user is not informed about this fact (ref.: FXM-15886).
