Script Factory
Script Factory does not stop correctly
Script Factory does not stop correctly if FluxMotors has been killed (ref.: FXM-15140).
Sometimes the store button status is bad
The store button is not enabled when a file is opened without modification (ref.: FXM-15136).
Script Factory freeze temporarily when running a script
When running a script, script factory gives the impression of freezing (while still running in the background). The editing window of the script becomes unresponsive, until the script is done executing (ref.: FXM-13138).
