All machines
The computation time has increased a lot for transient thermal computations
The computation time needed for the test Characterization/Thermal/Transient is much higher than in the previous version (14 minutes instead of 2 minutes, for instance). There is the same problem with the test Performance mapping - Efficiency map while computing user working point(s) analysis with thermal solving.
This issue will be fixed in the next version (ref.: FXM-15653 and FXM-15654).
These issues have been corrected.
No option to save the work after loss of license
Motor Factory 2022.3 does not give the option to save the work after loss of license. (FXM-15557, FXM-15556).
Error with automatic connection between FluxMotor and HyperStudy
Sometimes, an error occurs when exporting/opening a connector several times in succession (ref.: FXM-15510).
This issue has been corrected.
Internal optimization processes can crash
Sometimes, when FluxMotor® launches an optimization in the back end with HyperStudy®, due to an error in the internal process (evaluation of the objective functions), FluxMotor® crashes.
Moreover, without any log file to explain the issue, one cannot understand the cause of the system crash (ref.: FXM-13949).
