Induction machines – Motor Factory – Test environment
Error while testing and / or Exporting to Flux Skew
Sometimes, solving tests or exporting projects to Flux Skew is not allowed when solid conductors (wires) are represented in all phases and the test or export requires an initialization performed in the Steady State AC application. This occurs regardless of the winding type (Classic or hairpin). This mainly concerns IMSQ machines for Working Point - U,f,N
This will be fixed for the next version (ref.: FXM-15499)
This issue has been corrected.
