View Running Job Files
View the files of a running job.
Depending on the state of the job, the job files that you are viewing may be stored on either the local desktop or on the remote PAS server.
While a job is running results files are maintained on the remote PAS server. These files can be displayed by viewing the contents of the Running Folder. Once the job completes, the job results files are written to the Output tab.
Perform job management tasks like Terminate, Resubmit, Delete, Move to Queue, Download, and Custom Actions. The tasks buttons appear based on the Job Status.
You can also upload a file or a folder for a job in Running Folder when the job is in running state.
  1. Click the Jobs tab located in the upper left-hand of the page.
    The job monitoring page is displayed with the list of the jobs that is submitted to a cluster.
    Job Monitoring View
    Figure 1. Job Monitoring View
  2. Perform one of the following options:
    • Click the job name from the list.
    • Right click the job and click the View Details from the context menu.
    Tip: Click Last Submitted job link to view the properties of the last submitted job that is submitted.
    The job Summary tab is displayed.
    Job Summary Tab
    Figure 2. Job Summary Tab
  3. Click the Running Folder tab.
    The job running files page are displayed with Running Folder tab.
    Job Running Folder
    Figure 3. Job Running Folder
    Tip: You can view the files, create, edit, and save, upload a file, download, and tail, the job files. You may visualize your running job files using the result viewer.
