Add Altair One Using HTTPS
Add and connect to Altair One server using HTTPS to submit and monitor jobs.
Before you begin: You need the URL of an Altair One server https://www.altairone.com and a valid set of credentials.
All communication between Access Desktop and Altair One is encrypted.
  1. Open the Windows system tray.
  2. Double-click the Access Desktop icon .
  3. Click .
  4. Select Clusters.
    A Clusters dialog box is displayed.
  5. Select HTTPS from the drop-down list.
    Adding a Cluster
    Figure 1. Adding a Cluster
  6. Enter a Cluster Display Name.
    Note: You can use alphanumeric characters for a cluster display name.
  7. Enter the Altair One URL https://www.altairone.com and select the Use Altair One checkbox.
    Figure 2. Connect to Altair One Server
  8. Click Add.
    A new web browser is launched and authenticates the user using the OpenID Connect (OIDC) and provides an authenticate code.
    Figure 3. OIDC Authentication to Altair One
  9. Click Next.
  10. Enter your Altair One login credentials.
    Figure 4. Altair One Credentials
  11. Click Verify.
    The device is connected and activated.
    Figure 5. Successful Login to Altair One
  12. Close the browser. Return to the Access Desktop application; the cluster is added, and a green check mark is displayed next to the cluster name.
    Figure 6. HTTPS Cluster Registered to Altair One
    Tip: Repeat the steps to add an additional HTTPS cluster.
