Add Access Web Using HTTPS
Add and connect to Access Web server using HTTPS to submit and monitor jobs.
Before you begin: You need the URL of an Access Web server and a valid set of credentials to add a cluster using HTTPS.
- Open the Windows system tray.
Double-click the Access Desktop icon
Click
Select Clusters.
A Clusters dialog box is displayed.
Select HTTPS from the drop-down list.
Figure 1. Adding a Cluster -
Enter a Cluster Display Name.
Note: You can use alphanumeric characters for a cluster display name.
Enter the Access Web URL in the format
https://<hostname>:4443. Hostname is the machine
where Access Web is installed.
Note: If a hostname is provided during the Access Web installation enter the Access Web URL using the hostname to register the HTTPS cluster. Similarly follow the same if IP address is provided.
Click Add.
A new web browser is launched and authenticates the user using the OpenID Connect (OIDC) and provides an authenticate code.
Figure 2. OIDC Authentication to Altair Access -
Click Submit.
The Access login page is displayed.
Enter your credentials.
Figure 3. Access Web Login -
Click Log In.
Figure 4. Successful Login to Access -
Close the browser. Return to the Access Desktop application; the
cluster is added, and a green check mark is displayed next to the cluster
name.
Figure 5. HTTPS Cluster Registered to AccessTip: Repeat the steps to add an additional HTTPS cluster.
