Import, Export, and Edit Output Controls
Use the Output table tool to import, export, and edit output controls.
From the Setup ribbon, Output tool group, click the
Output table tool.
Figure 1.The Outputs dialog opens. -
Import output controls.
- In the Outputs dialog, select a type of output control from the tabs.
Click
to browse for output controls.
Tip: In the Outputs dialog, enable the checkbox to import and export outputs from all tabs. -
Export output controls.
Click
to export output controls.
Edit output controls.
- Edit properties of the output controls by editing the Output table.
