SimLab Tutorial Summary: 3D Wireless Power Transfer
The coupler in an inductive power transfer system includes the following elements, an energy transmitter, and an energy receiver, each includes a coil as well as ferromagnetic material.
For this device, its mutual-inductance value is the most important physical quantity. Because the mutual-inductance value determines the ability to transmit power, it is of great significance to the design of the coupler and the control circuit.
Basic EM analysis
All physics definitions of the studying device can be realized with the proposed [MT3D Workflow] toolbar:
SimLab-Flux provides two basic coil modeling methods, including meshed coil and non-meshed coil, as shown below:
After solving the scenario, SimLab can provide some basic post-processing for the EM analysis, including the mutual-inductance calculation. As shown below, the mutual-inductance values under the two coil modeling methods are very close.
Example access
All files corresponding to this example are accessible in the Knowledge Base in Altair community:- to follow the example step by step, the corresponding files are in
"Example_name_StepByStep" folder containing:
- Tutorial folder: contains the document describing the example step by step
- InitialFiles folder: contains *.slb databases and files needed to build the example step by step
- to play scripts and retrieve SimLab and Flux project, the corresponding files
are in "Example_name_PlayScripts" folder containing:
- ScriptsTutorial folder: contains script files to be able to play each analysis
- Input folder: contains initial *.slb databases and all necessary files to play each analysis script
- Output folder: empty (contains the obtained results after the script execution)
