Altair® Monarch®
Specify Source (and Destination) Files Screen
Use this screen to specify the source files you want to alter in some way (e.g., XML models you want to convert into binary models), and to specify a storage location for the converted files.
Note: The contents of this screen are determined by the task you select on the Choose a Task screen. Not all of the items listed below will always be present.
Options
The Specify Source Files screen includes the following options:
SOURCE
  • Folder - Enter the path to the folder that contains the files you want to work with (e.g., XML models that you want to convert into binary models).
  • Folder icon - Click to display the Browse for Folder dialog, which you can use to navigate to the desired folder.
  • Include Subfolders - Select to include any files in all subfolders of the specified source folder.
  • Filename - Enter the name of the file you want to utilize (i.e., the model or project file) or enter a wildcard and the appropriate extension (e.g., *.dmod).
  • Folder icon - Click to open the Browse for Folder dialog, which you can use to navigate to the desired folder or file.
  • Purge Before - Use this field to define the date up to when entries will be purged for the specified files.
  • Purge Before Checkbox - Check this box to purge all entries for the specified files.
DESTINATION
  • Folder - Enter the name of the location (i.e., the destination folder) where you want to place the converted files.
  • Folder icon - Displays the Browse for Folder dialog.
  • Back - Displays the Choose a Task screen.
  • Next - Displays the Task Summary screen.
  • Cancel - Closes Monarch Utility.
  • Help - Displays this help topic.
