Altair® Monarch®
Task Summary Screen
This screen displays a text summary of the task that the Monarch Utility will perform when you click the Finish button. Upon completion of the task, it displays the Monarch Utility Process Log.
Options
The Task Summary screen includes the following options:
  • Back - Click to go back to the previous screen of the Monarch Utility wizard.
  • Finish - Click to execute the task summarized on the screen.
  • Cancel - Click to close the Monarch Utility without performing the task.
  • Help - Displays this help topic.
This displays on the Task Summary screen after a task has been run. It contains the following information:
  • Operation Type - Displays the type of task (e.g., displays "Copy" if the task copied models or projects from one location to another).
  • Source Path - Displays the path of the task’s source files.
  • Destination Path - Displays the destination path of the task’s files.
  • Status - Displays the status of the task (e.g., displays "Success" if the task ran successfully).
  • Message - If an error occurs, displays an error message with relevant information.
