Find Dialog
Use this dialog to locate text in any cell in the grid displayed on the Examine and Modify External References screen and the Examine and Modify Authors and Descriptions screen. To access the Find dialog, click the Find button on either screen.
Options
The Find dialog includes the following options:
Find What - Enter the text string you want to find.
Find Next - Click to find the next instance of the text string in the Find What field.
Match Case - Select to enforce a case-sensitive search for the text in the Find What field. Note: If you don't select this check box, all instances of the text in the Find What field will be found, regardless of their case.
Up - Click to search up from the cursor's position in the grid.
Down - Click to search down from the cursor's position in the grid.
Cancel - Cancels the find operation and closes the dialog without saving any changes.
