HyperCrash
Database Main Table
Database Main Table
Previous topic Next topic Expand/collapse all hidden text
Database Main Table
The file, $MCRASHDIR/modmng/database_main.tbl defines the path of the different databases:
Two types of databases may be defined:
•Private database: just for the user
•Public database: for any user
Card 1:
This card defines the type of database and their path:
/MODMNG/DATABASE/type
<full_path>database_name_table.tbl
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•DATABASE
is a keyword
Keyword
No
•type
is a keyword which define the type of database:
•PRIVATE for the private database
•PUBLIC for the common database
Keyword
No
•database_name_table.tbl
is the file name (with the full path) of the database table list of each databases
String
No
Several database table can be defined under this keyword line.
Card 3: end of file
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
/MODMNG/DATABASE/PRIVATE
$HOME/private_database/private_database_1.tbl
$HOME/private_database/private_database_2.tbl
/MODMNG/DATABASE/PUBLIC
$MCRASHDIR/database/database1.tbl
$MCRASHDIR/database/database2.tbl
$MCRASHDIR/database/database3.tbl
/END
Database table file
For each database, there is only one table file (.tbl). This file defines all the sub-models (B00 files) located in the database.
For all the details about the sub-models (file B00), please refer to the B00 Description manual.
Card 1: Database path
/MODMNG/DATABASE/DIRECTORY
directory_path
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•DATABASE
is a keyword
Keyword
No
•DIRECTORY
is a keyword
Keyword
No
•directory_path
is the default directory path where the sub-model (B00 file) will be stored
String
No
Card 2: model description
/MODMNG/DATABASE/MODEL
/path/File_name
1
2
3
4
5
6
7
8
9
10
Key_1
Key_2
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•DATABASE
is a keyword
Keyword
No
•MODEL
is a keyword
Keyword
No
•File_name
is the file name of the B00 sub-model defined with its full path and/or with the variable, $MCRASHDIR.
String
No
•Key_i
is the keyword list used to defined the model. The keywords are defined in the file, $MCRASHDIR/modmng/keyword.tbl
String
No
To write a keyword with more than 8 characters, the character ’@’ will be set at the first position of the next field (See the section Keyword).
Card 3: end of file
/END
Where:
Unit
•END
Keyword
No
$MCRASHDIR/database/MODEL01B00
WINDSHIE@LD     FEM     FRONT
$MCRASHDIR/database/MODEL02B00
ENGINE   FEM     FRONT
/END
Go to
Model Manager Module Environment File
