HyperCrash
Loadcase Main Table
Loadcase Main Table
Previous topic Next topic Expand/collapse all hidden text
Loadcase Main Table
The model building refers to a loadcase (example: front crash on rigid wall at 35 mph.). The loadcase file location is set in a main table file, $MCRASHDIR/modmng/loadcase_main.tbl.
Card 1: Loadcase group
/MODMNG/LOADCASE/GROUP
Group_loadcase_name
Nb_loadcase_type
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•LOADCASE
is a keyword
Keyword
No
•GROUP
is a keyword
Keyword
No
•Group_loadcase_name
is the name of the loadcase group which will be displayed in the Model Manager page
String
No
•Nb_loadcase_type
is the number of loadcase type to read in this group
String
No
Card 2: Loadcase type
/MODMNG/LOADCASE/TYPE
Loadcase_name
Loadcase_file_name
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•LOADCASE
is a keyword
Keyword
No
•TYPE
is a keyword
Keyword
No
•Loadcase_name
is the name of the loadcase which will be displayed in the Model Manager graphic user interface (window)
String
No
•Loadcase_file_name
is the name of the loadcase file (defined with the full path and/or with the variable $MCRASHDIR)
String
No
Card 3: end of file
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
Front crash
2
Front Crash 1
$MCRASHDIR/loadcase/front_crash_1.tbl
Front Crash 2
$MCRASHDIR/loadcase/front_crash_2.tbl
Rear Crash
$MCRASHDIR/loadcase/rear_crash.tbl
Side Crash
$MCRASHDIR/loadcase/side_crash.tbl
/END
Loadcase file description
The loadcase file may be defined where the user wants because the full path is defined in the loadcase main table. The default setting is located in the directory, $MCRASHDIR/loadcase/.
Card 1:
This card defines the keyword that will be displayed on the Model Manager sub-model list.
/MODMNG/LOADCASE/SCREEN_KEYWORD
keyword_group_name_1
keyword_group_name_2
keyword_group_name_n
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•LOADCASE
is a keyword
Keyword
No
•SCREEN_KEYWORD
is a keyword
Keyword
No
•keyword_group_name_i
is the name of the keyword group(s) name that will be displayed in the Model Manager graphic user interface (window).
String
No
Card 2: sub-model definition
This card defines a sub-model (or component) described with keywords that will be loaded to create the complete model according to the loadcase.
/MODMNG/LOADCASE/MODEL
submodel_name
1
2
3
4
5
6
7
8
9
10
Key_1
Key_2
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•LOADCASE
is a keyword
Keyword
No
•MODEL
is a keyword
Keyword
No
•submodel_name
is the name of the sub-model file (defined with the full path and/or with the variable, $MCRASHDIR)
Keyword
No
•Key_I
is the name of the keyword (8 characters only)
String
No
To write a keyword with more than 8 characters, the character ’@’ will be set on the first position of the next field (See the section Keyword).
Card 3: automatic positioning (optional)
/MODMNG/POSITIONING/DIRECTION
1
2
3
4
5
6
7
8
9
10
X_coord
Y_cood
Z_coord
Angle
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•POSITIONING
is a keyword
Keyword
No
•DIRECTION
is a keyword
Keyword
No
•X_coord
is the x component of the direction vector
Real
No
•Y_coord
is the y component of the direction vector
Real
No
•Z_coord
is the z component of the direction vector
Real
No
•Angle
is the rotation angle around the vector
Real
Degree
If the vector direction is also defined in the submodel (B00 file), HyperCrash will rotate the submodel until both directions are the same. The rotations are done around the point (0,0,0).
If the Angle value is different from 0, HyperCrash will rotate the model around the vector direction and around the point (0,0,0).
/MODMNG/POSITIONING/BOX2BOX
1
2
3
4
5
6
7
8
9
10
X_param_main
Y_param_main
Z_param_main
X_param_sub
Y_param_sub
Z_param_sub
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•POSITIONING
is a keyword
Keyword
No
•BOX2BOX
is a keyword
Keyword
No
•i_param_main
defines the position on the main model ( 0 < param > 1) in the three directions of the global frame
Real
No
•i_param_sub
defines the same position on the submodel (B00 file) in the three directions of the global frame
Real
No
Both models are defined with their external box and in their local frame, between 0 and 1.
HyperCrash will translate the model, until both positions are on the same place.
external_box.zoom80
Card 4: automatic positioning (optional)
/MODMNG/POSITIONING/TRANSLATION
1
2
3
4
5
6
7
8
9
10
X_value
Y_value
Z_value
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•POSITIONING
is a keyword
Keyword
No
•TRANSLATION
is a keyword
Keyword
No
•i_value
defines the translation value in the three directions of the global frame x, y, and z.
Real
Length
The submodel will be translated with the defined values in the global frame.
Card 5: end of file
/END
Where:
Unit
•END
Keyword
No
Component
Model Type
Crash type
Engine
ENGINE  FEM     FRONT
Radiator
RADIATOR FEM    FRONT
Offset deformable barrier
ODB     FEM     FRONT
             0.5             0.0             0.0
             0.5             1.0             0.0
             0.0            -1.0             0.0
/END
Go to
Model Manager Module Environment File
