HyperCrash
Model Manager Module Environment File Description
Previous topic Next topic Expand/collapse all hidden text
Keyword
The model will be located in the database with a keyword list that will be used to research the model in the database.
All the keyword are defined in the file, $MCRASHDIR/modmng/keyword.tbl.
Several keyword lists can be defined in the keyword.tbl file. Each keyword list is defined inside a keyword group.
Card 1:
/MODMNG/KEYWORD
keyword_group_name
1
2
3
4
5
6
7
8
9
10
Key_1
Key_2
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•KEYWORD
is a keyword
Keyword
No
•keyword_group_name
is the name of the keyword group
String
No
•Key_i
is the name of the keyword (8 characters only)
String
No
To write a keyword with more than 8 characters, the character ’@’ will be set at the first position of the next field (See the keyword FUEL TANK in the Example below).
Card 2: end of file
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
/MODMNG/KEYWORD
Component
MOTOR   DOOR    TIRE    ENGINE  SEAT    RADIATORFUEL TAN@K      ODB
/MODMNG/KEYWORD
Model Type
FEM     BEAM    RBODY   MASS
/MODMNG/KEYWORD
Crash type
FRONT   REAR    SIDE    ALL
/END
Go to
Loadcase Main Table
Database Main Table
See also
