HyperCrash
B00 File Description
The HyperCrash Model Manager database file (B00 file) is composed of a RADIOSS input deck (D00 file – 41 Block Format) and at the bottom of this file, some information is necessary for HyperCrash.
Header
The specific part of the B00 file starts with the keyword line:
/MODMNG/START
Some comments can be added between these lines. These comments will be displayed in the message window when the B00 file is loaded.
These lines must start with the # character.
Example:
/MODMNG/START
# This model will be merged with this model
M00 file information
All information that are in the M00 files are included in the B00 file between the two following keyword lines.
Example:
/MODMNG/MCRASH/START
spotwelds information
bolts information
tree information
/MODMNG/MCRASH/END
Positioning information
This keyword line is used to define a main direction for a model. This information will be used during the loading of the file for the automatic positioning.
/MODMNG/POSITIONING/DIRECTION
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
  x-coordinate    y-coordinate    z-coordinate
Example for a full car model:
            1.0             0.0             0.0
Example for a frontal rigid wall:
# START OF MODMNG SPECIFIC INSTRUCTIONS
/MODMNG/START
# Rigid Wall at x = 0
/MODMNG/HyperCrash/START
/MODMNG/HyperCrash/END
          1.0           0.0           0.0
/MODMNG/END
# END OF MODMNG SPECIFIC INSTRUCTIONS
Note:Further information for the automatic positioning is defined in the Loadcase file description.
End of the B00 specific information
The specific part of the B00 file ends with the keyword line:
/MODMNG/END
Where:
Unit
•MODMNG
is a keyword
Keyword
No
•END
is a keyword to finish the input.
Keyword
No
