HyperCrash
Themes
Themes
Previous topic Next topic Expand/collapse all hidden text
Themes
The file, $MCRASHDIR/themes/mcrash1rc defines the HyperCrash window parameters.
It is strongly recommended to not modify this file.
Cards:
Keyword{
Arguments 1
Arguments 2
Arguments n
The comment lines start with the # character.
hmtoggle_plus1Example
# pixmap_path "<dir 1>:<dir 2>:<dir 3>:..."
# include "rc-file"
# style <name> [= <name>]
#   <option>
# widget <widget_set> style <style_name>
# widget_class <widget_class_set> style <style_name>
pixmap_path "."
style "defaultfont"
 font = "-adobe-helvetica-medium-r-normal--*-120-*-*-*-*-*-*,*"
# common default
style "window"
 bg[NORMAL] = { 0.2, 0.2, 0.4 }
style "toggle_button" = "default"
 bg[ACTIVE] = { 1.0, 1.0, 0 }
 font = "-Adobe-Helvetica-Medium-R-Normal--12-120-75-75-P-67-ISO8859-1"
#widget_class "GtkWindow" style "window"
widget_class "*GtkCheckButton*" style "toggle_button"
widget_class "*GtkRadioButton*" style "toggle_button"
#widget_class "*Gtk*Pan*" style "window"
# possible priorities are (in ascending order):
# lowest
# gtk         (used by gtk for internal class bindings)
# application (for hard coded bindings on application basis)
# rc          (used implicitel by rc files)
# highest
Go to
Main Module Environment File Description
