HyperCrash
Quality Criteria
Quality Criteria
Previous topic Next topic Expand/collapse all hidden text
Quality Criteria
The file, $MCRASHDIR/mcrash_criteria defines the Quality / Check Element of Tree Selection parameters, where the user can error check an element.
/Keyword/Nb_param/Param_1/Param_2/…/Param_nb_param
Where:
Unit
•Keyword
is the keyword defining the element quality criteria.
String
No
•Nb_param
is the number of parameters to read
Integer
No
•Param_i
is the element type that will be checked with the element quality criteria
String
No
Card 1: Limit of the bad elements
1
2
3
4
5
6
7
8
9
10
Criteria_S
Criteria_1
Criteria_2
Criteria_3
Criteria_4
Where:
Unit
•Criteria_i
is the value that defines the bad element limit for mesh class i.
Real
Depends on the criteria
Card 2: Limit of the good elements
1
2
3
4
5
6
7
8
9
10
Criteria_S
Criteria_1
Criteria_2
Criteria_3
Criteria_4
Where:
Unit
•Criteria_i
is the value that defines the good element limit for mesh class i.
Real
Table of keywords and parameters:
Criteria name
Keywords
Criteria unit
Time step: (see RADIOSS manual)
Computed value has to be greater than limit.
ELT_TIMESTEP
SHELL3N
SHELL4N
SPRING
BEAM
TRUSS
SOLID
Time
Minimum mesh size
min_mesh_size_a
ELT_MINSIZE
SHELL4N
SHELL3N
SPRING
BEAM
TRUSS
Length
Maximum mesh size
max_mesh_size
Computed value has to be smaller than limit.
ELT_MAXSIZE
SHELL4N
SHELL3N
SPRING
BEAM
TRUSS
Length
Minimum angle: the smallest interior angle of the element projected onto its middle plane.
middle_plane_angle
ELT_MINANGLE
SHELL4N
SHELL3N
Degrees
Maximum angle: the greatest interior angle of the element projected onto its middle plane.
middle_plane_angle_max
ELT_MAXANGLE
SHELL4N
SHELL3N
Degrees
Warping:
The normal at each node is computed, that is, the normal of the plane including this node and its two neighbors.
The two angles between opposite normal vectors are computed.
The greater one of these two angles is the warping. Computed value has to be smaller than limit.
ELT_WARPING
SHELL4N
Degrees
Aspect ratio: aspect ratio is calculated as (length of longest side / length of shortest side). Computed value has to be smaller than limit (closer to 1.0).
ELT_ASPECT
SHELL4N
No
4 nodes shell degeneration
ELT_DEGENERATED
SHELL4N
No criteria
Minimum mass
ELT_MINMASS
SPRING
BEAM
TRUSS
Mass
Maximum mass
ELT_MAXMASS
SPRING
BEAM
TRUSS
Mass
Percentage of 3 node shell elements in parts
PART_TRIAS
No
Maximum mass of the parts
PART_MASS
Mass
Card 3:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
#-- CLASS S ---|--- CLASS 1 ---|--- CLASS 2 ---|--- CLASS 3 ---|--- CLASS 4 ---|
/ELT_TIMESTEP/6/SHELL3N/SHELL4N/SPRING/BEAM/TRUSS/SOLID
           8e-7            8e-7            8e-7            8e-7            8e-7
           1e-6            1e-6            1e-6            1e-6            1e-6
/ELT_MINSIZE/2/SHELL3N/SHELL4N
              6               5               5               6               6
              8
/ELT_MAXSIZE/2/SHELL3N/SHELL4N
            100              10              20              40             100
/ELT_MINANGLE/1/SHELL3N
             30              45              45              30              30
             45
/PART_TRIAS/
             15              15              15              20              30
             10              10              10              15              20
/PART_MASS/
          20e-3           20e-3           20e-3           20e-3           20e-3
/END
Go to
Main Module Environment File Description
