HyperCrash
Intersections / Penetrations Criteria
Previous topic Next topic Expand/collapse all hidden text
The file, $MCRASHDIR/mcrash_preferences defines the Quality / Contact menu parameters.
Parameters for intersection
Card 1:
/CHECK/INTERSECTIONS/MAX_RATIO_OF_AUTO_MOVED_NODES
1
2
3
4
5
6
7
8
9
10
Ratio
Where:
Unit
•Ratio
defines the maximum percentage of nodes from one part that HyperCrash is allowed to move automatically to correct the same intersection (default is 0.1 = 10%).
Real
No
Card 2:
/CHECK/INTERSECTIONS/GAP_SEARCH
1
2
3
4
5
6
7
8
9
10
Gap_search
Where:
Unit
•Gap_search
defines the box to search the intersection (default = 1).
Real
Length
Caution: It is dangerous for the quality of the mesh to have a value for Gap_search that is too high. This can cause memory trouble in the Disintersector and an abort of HyperCrash. The Gap_search should be much smaller than the minimum element size.
Card 3:
/CHECK/INTERSECTIONS/GAP_SEARCH_AFTER_TOGGLE
1
2
3
4
5
6
7
8
9
10
Gap_search
Where:
Unit
•Gap_search
defines the box to search the intersection when using the toggle function (default = 2).
Real
Length
This option is only active if GAP_SEARCH_AFTER_TOGGLE is bigger than Gap_search. Thus, the Semiautomatic Disintersector can propose new positions for nodes, which are not moved by the Automatic Disintersector, because their distance to the next element is too long.
Caution:The same warning as for Gap_search applies. GAP_SEARCH_AFTER_TOGGLE should not be bigger than the average element size.
Card 4:
/CHECK/INTERSECTIONS/GAP_AFTER_DISINTERSECTION
1
2
3
4
5
6
7
8
9
10
Gap_value
Where:
Unit
•Gap_value
is the distance of the depenetration after an automatic disintersection. (default = 0.1).
Real
Length
Card 5:
/CHECK/INTERSECTIONS/MAX_NB_CANDIDATES
1
2
3
4
5
6
7
8
9
10
Number_of_candidates
Where:
Unit
•Number_of_candidates
defines the size of the memory allocation during the depenetration (default = -4).
If Number_of_candidates is positive: the number of candidate value will increase one by one if necessary.
If Number_of_candidates is negative: the number of candidate value will be doubled if necessary.
Real
No
Card 6:
/CHECK/INTERSECTIONS/MIN_DISTANCE_FACTOR
1
2
3
4
5
6
7
8
9
10
Factor
Where:
Unit
•Factor
is a multiplier of the Gap value for the automatic preliminary node displacement. This factor must be defined strictly between 0 and 1. (default = 0.001).
If the value is lower than 0, no automatic preliminary displacement will be done.
Real
No
Card 7:
/CHECK/INTERSECTIONS/AUTO_PREPARE_DISINTERSECTION/keyword
Where:
Unit
•keyword
is a flag YES or NO which allows to compute propositions for a disintersection directly after an intersection check.
Default = YES.
In case HyperCrash fails during the disintersection proposal computation, set the keyword to NO.
Keyword
No
Card 8:
/CHECK/INTERSECTIONS/TRIPLE_EDGES_ARE_CONTOUR/keyword
Where:
Unit
•keyword
is a flag YES or NO. This option allows the use of triple edges as part contour. The automatic disintersection then works better. The option is active for parts of shell elements only, not for parts of solids.
Default = YES.
Keyword
No
Card 9:
/CHECK/INTERSECTIONS/PROJECT_ON_BOTH_PARTS/keyword
Where:
Unit
•keyword
is a flag YES or NO. With YES, all elements (segments) of the two intersecting parts are used for the projection of the nodes "on the wrong side." With NO, the nodes are only projected on the segments of one of the parts.
Default = YES.
Keyword
No
Card 10:
/CHECK/INTERSECTIONS/PERFORMANCE_TEST/keyword
Where:
Unit
•keyword
is a flag YES or NO. With YES, a timer for some actions (check of intersections, automatic disintersection) is activated.
Default = NO.
Keyword
No
Card 11:
/CHECK/INTERSECTIONS/AUTO_SELECT_NEXT/keyword
Where:
Unit
•keyword
is a flag YES or NO. If YES: The next part couple is selected automatically. This option reduces the number of user actions (mouse clicks). If NO: The next part couple is not selected automatically.
Default = YES.
Keyword
No
Card 12:
/CHECK/INTERSECTIONS/INTERFACE_TYPE_IF_PARTS_CHECKED/type
Where:
Unit
•type
is a keyword which defines which interface type will be displayed in the disintersection window:
•Type_7
•Type_7_AND_11
Default = Type_7
Keyword
No
Card 13:
/CHECK/INTERSECTIONS/DISPLAY_LINEGROUPS/keyword
Where:
Unit
•keyword
Is a keyword YES or NO. If YES, a first column with the number of intersections (that is, groups of connected intersection lines) for each couple of intersecting parts is displayed. At the same time, a "spin-button" type selector is displayed which allows the showing of all the intersection lines (of a part couple) at the same time, or only one group of connected intersection lines at a time.
Keyword
No
Card 14:
/CHECK/INTERSECTIONS/EPSILON_PARALLELISM
1
2
3
4
5
6
7
8
9
10
Limit
Where:
Unit
•Limit
Is the minus value of the normal direction of two intersected segment. If the value < Limit, then the segments are parallel. Intersection is not computed. If the value > Limit, then the segments are not parallel. Intersection is computed.
Default = 1e-10.
Real
No
Parameters for penetrations
Card 15:
/CHECK/DEPENETRATOR/SMOOTH
1
2
3
4
5
6
7
8
9
10
Number_of_cycles
Where:
Unit
•Number_of_cycles
is the number of cycles for the smoothing function.
Recommended value = 3
Integer
No
Card 16:
/CHECK/DEPENETRATOR/GAP_PART_CHECK
1
2
3
4
5
6
7
8
9
10
Gap_default
Where:
Unit
•Gap_default
is the gap which is used for the penetration check of the "Tree selection".  Negative values mean "variable gap".
Default = -1
Real
No
Card 17:
/CHECK/DEPENETRATOR/Gap_mini
1
2
3
4
5
6
7
8
9
10
Gap_mini
Where:
Unit
•Gap_mini
is the minimum gap which is used for the penetration check of the "Tree selection" if it is checked with variable gap.
Default = 0.000001
Real
Length
Card 18:
/CHECK/DEPENETRATOR/GAP_PARAMETERS
1
2
3
4
5
6
7
8
9
10
a
b
Where:
Unit
•a
Is a multiplier of the defined interface gap (default = 1)
Real
No
•b
Is an additional value to the defined interface gap (default = 0)
Real
Length
These parameters are used to compute the depenetration gap with the following equation:
gap_for_depenetration = gap_defined_interface * a + b
Parameters for window setting
Card 19:
/CHECK/DEPENETRATOR/SHOW_GAP_PARAMETERS/Flag
Where:
Unit
•Flag
Yes: The gap parameters option will be displayed.
No: The gap parameters option will not be displayed.
Keyword
No
Card 20:
/CHECK/DISINT_DEPEN/MAX_DISPLACEMENT
1
2
3
4
5
6
7
8
9
10
Limit_good
Limit_bad
Where:
Unit
•Limit_good
All the penetrations with a value higher than Limit_good will be displayed in orange.
Real
Length
•Limit_bad
All the penetrations with a value higher than Limit_bad will be displayed in red.
Real
Length
Other cards
Card 21:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
0.1
5.0
20.0
0.1
0
/CHECK/INTERSECTIONS/DISINTERSECT_LINE_BY_LINE/YES
#-60
-4
/CHECK/INTERSECTIONS_DISPLAY/INTERFACE_TYPE_IF_PARTS_CHECKED/TYPE_7_AND_11
/CHECK/INTERSECTIONS/TRIPLE_EDGES_ARE_CONTOUR/YES
#10
3
#/CHECK/DEPENETRATOR/NB_NORMAL_CYCLES
#3
/CHECK/DEPENETRATOR/GAP_MIN
0.1
/CHECK/DEPENETRATOR/SHOW_GAP_PARAMETERS/YES
#- limit good -|- limit bad   -|
            0.5             2.0
/END
Go to
Main Module Environment File Description
