HyperCrash
Model Checker
Model Checker
Previous topic Next topic Expand/collapse all hidden text
Model Checker
The file, $MCRASHDIR/modelchecker defines the Quality / Model Checker menu parameters.
The user can control the range of values that are marked as ERROR or WARNING.
Card 1: check group
/MODCHK/GROUP
1
2
3
4
5
6
7
8
9
10
Group_name
Where:
Unit
•MODCHK
is a keyword
Keyword
No
•GROUP
is a keyword
Keyword
No
•Group_name
is the name of the check group.
String
No
The check groups contain several checks.  If the Model Checker list is sorted by "Check," the group titles are displayed in black.
Card 2: Check
/MODCHK/CHECK/level/keyword_check/object_type
1
2
3
4
5
6
7
8
9
10
Check_title
Icon_title
Popup_title
Where:
Unit
•MODCHK
is a keyword
Keyword
No
•CHECK
is a keyword
Keyword
No
•level
is the check level: ERROR, WARNING or INFO
Keyword
No
•keyword_check
is the checked keyword (see list of available checks)
Keyword
No
•object_type
is the RADIOSS keyword of the object type to check
Keyword
No
•Check_title
is the check title
Keyword
No
•Icon_title
is the default name displayed in the modify page of the checked entities (not mandatory)
Keyword
No
•Popup_title
is the default name displayed in the tooltips and pop-up menu of Modify Notebook sheet of the checked entities, when there are several entities in the same Modify sheet. (optional – Used only for SPRING.)
Keyword
No
Note:
•For checks that concern the model, for example, RandomNoise, no object_type is read.
•For checks that are available only for a single object_type, for example, RbodyCommonSlave, it is not necessary to give this type.
•The title of the check is displayed in the Model Checker list. This title is also used for the tooltips and pop-up menus in the ".../Modify" pages.
Check list:
Keyword_check
Available for
Check
Standard level
RandomNoise
(Model)
Check if there is random noise in the model.
WARNING
NbInMode
all object types
Check the number of NODE, SHELL, RBODY… in the model.
INFO
DoubleId
all object types
Check if there is the same identifier number between same type objects.
ERROR
Unused
MAT
PROP
Check the unused object.
WARNING
FreeNodes
(Model)
Check the free nodes (unlinked with object) in the model.
WARNING
ThNbSelected
all object types in TH
Check the number of each entities set in TH.
INFO
NegativeVolume
BRICK
TETRA4
TETRA10
SHEL16
BRIC20
Check the volume of the 3D elements.
ERROR
ShellDegenerated
SHELL
Check the connectivity of the SHELL elements.
ERROR
ShellDegeneratedOtherThan3And4
SHELL
ERROR
ShellElemThickness
SH3N
SHELL
Check if thickness is directly set on the elements definition.
WARNING
PropShellTooThick
PROP
Check if the thickness defined in the property of shell is higher than a defined value.
WARNING
PropShellTooThin
PROP
Check if the thickness defined in the property of shell is smaller than a defined value.
WARNING
PropShellThickness0
PROP
Check if the thickness defined in the property of shell is less than  or equal to 0.
ERROR
1dLooseNode
BEAM
SPRING
TRUSS
Check if the nodes of the 1D elements are not connected.
ERROR
1dConnectivity
BEAM
SPRING
TRUSS
Check if nodes of the 1D elements are connected with the same element type and the same PID or with only added mass, accelerometer or section.
WARNING
Spring13Length0
SPRING
Check if springs with a property type have null length.
ERROR
Prop4or8
PROP
Check if there is spring type 4 or 8 in the model.
WARNING
NULLArea_of_Beam_Truss
PROP
Check if the area of the beam and truss property are less than or equal to 0.
ERROR
NULLInertia_of_Beam_Spring
PROP
Check if the area of the beam and spring property are less  than or equal to 0.
ERROR
NULLMass_Spring
PROP
Check if the mass of the spring property is less than or equal to 0.
ERROR
Interface2BadIsearch
INTER
Check if the Isearch = 1 in the interface type 2.
WARNING
Check if the Isearch is less than 0 and greater than 2 in the interface type 2.
ERROR
RbodyCommonMaster
RBODY
Check if several rigid bodies have the same master nodes.
ERROR
RbodyMasterOnElem
RBODY
Check if some rigid bodies master nodes are set on elements.
WARNING
RbodyCommonSlave
RBODY
Check if some rigid bodies have common slave nodes.
ERROR
RbodyCascade
RBODY
Check if some master nodes of rigid bodies are not slave nodes of others rigid bodies.
WARNING
Rbody1Slave
RBODY
Check if the rigid body has only one slave node.
WARNING
RbodyMasterIsSlave
RBODY
Check if the master node of the rigid body is also slave of the same rigid body.
ERROR
RbodyNotSpherica
RBODY
Check if there is the spherical inertia option if the master node is small.
WARNING
RbodyId2MasterId
RBODY
Check if the ID of the master node is not the same as the RBODY ID.
WARNING
AdmasNodesNotOnElem
ADMAS
Check is nodes with added masses are not connected to elements (free).
WARNING
TripleEdgeShell
SHELL
SH3N
Check if the edge of the shell is used more than two times in the model.
WARNING
SkewsAxis
SKEW
Check if the skew frame is correctly defined.
ERROR
SectionsNodes123
SECTION
Check if the three nodes defining the skew frame are correctly defined.
ERROR
Card 3: Correction
/MODCHK/CORRECTION/keyword_correction
1
2
3
4
5
6
7
8
9
10
Correction_name
Where:
Unit
•MODCHK
is a keyword
Keyword
No
•CORRECTION
is a keyword
Keyword
No
•keyword_correction
is a keyword for the correction (see the list below)
Keyword
No
•Correction_name
is the name of the correction displayed in HyperCrash.
String
No
Available correction:
Keyword_check
Available Correction
RandomNoise
DeleteRamdomNoise
DoubleId
CorrectDoubleId
Unused
Delete
FreeNodes
DeleteFreeNode
ThNbSelected
NbInModel
NegativeVolume
CorrectSolidNegativeVolume
ShellDegenerated
CorrectShellDegenerated
CorrectShellDegeneratedOtherThan3And4
ShellElemThickness
DeleteShellElemThickness
PropShellTooThick
ChangeManually
PropShellTooThin
ChangeManually
PropShellThickness0
ChangeManually
1dLooseNode
ModifyManually
1dConnectivity
ModifyManually
Spring13Length0
ModifyManually
Prop4or8
Disconnect
ChangeManually
ChangeManually
ChangeManually
NULLMass_Spring
ChangeManually
Delete
CorrectIsearchInType2
RbodyCommonMaster
ModifyManually
RbodyMasterOnElem
ModifyManually
RbodyCommonSlave
ModifyManually
RbodyCascade
ModifyManually
Rbody1Slave
ModifyManually
RbodyMasterIsSlave
ModifyManually
RbodyNotSpherica
ModifyManually
RbodyId2MasterId
CorrectRbodyId2MasterId
AdmasNodesNotOnElem
ModifyManually
TripleEdgeShell
SkewsAxis
SectionsNodes123
Card 4:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
hmtoggle_plus1Example
/MODCHK/GROUP
Accelero Cards
/MODCHK/CHECK/INFO/NbInModel/ACCEL
Number of Accelero
Number
/MODCHK/CHECK/INFO/ThNbSelected/ACCEL
Nb. TH-selected Accelero
Number
/MODCHK/CHECK/ERROR/DoubleId/ACCEL
Double ID's of Accelero
Double ID
/MODCHK/CORRECTION/CorrectDoubleId
Modify ID automatically
/MODCHK/GROUP
Dummy Cards
/MODCHK/CHECK/INFO/NbInModel/DUMMY
Number of Dummy
Number
/MODCHK/CHECK/ERROR/DoubleId/DUMMY
Double ID's of Dummy
Double ID
/END
Go to
Main Module Environment File Description
