HyperCrash
Spotweld
Spotweld
Previous topic Next topic Expand/collapse all hidden text
Spotweld
The file, $MCRASHDIR/spotweld/rspdef defines the spotweld creation parameters.
Card 1:
1
2
3
4
5
6
7
8
9
10
Spotgap
Lengthmin
Lengthmax
Where:
Unit
•Spotgap
is the research gap for point projection on the elements
Real
Length
•Lengthmin
is the minimum acceptable spring length for the spotweld
Real
Length
•Lengthmax
is the maximum acceptable spring length for the spotweld
Real
Length
Card 2:
1
2
3
4
5
6
7
8
9
10
Gapfactor
Doublegap
Angle
Where:
Unit
•Gapfactor
is a factor to search the elements
Real
Length
•Doublegap
is the minimum length between two spotwelds
Real
Length
•Angle
is the maximum angle between the normal of the element and the spring
Real
Degree
Card 3:
1
2
3
4
5
6
7
8
9
10
Mass
Inertia
Where:
Unit
•Mass
is the mass of the spring set in the property
Real
Mass
•Inertia
is the inertia of the spring set in the property
Real
Mass*Length²
Card 4:
1
2
3
4
5
6
7
8
9
10
Nsfunc
Where:
Unit
•Nsfunc
is the number of the function Thickness vs. force
Integer
No
Card 5: defines Nsfunc values
1
2
3
4
5
6
7
8
9
10
Thickness
Maxforce
Where:
Unit
•Thickness
is the minimum thickness value of the welded parts
Real
Length
•Maxforce
is the maximum shear force in the spring before rupture
Real
Force
Card 7: additional Nsfunc
1
2
3
4
5
6
7
8
9
10
Tens_factor
Where:
Unit
•Tens_factor
is the factor defining the ratio between tension and shear
Real
No
Card 7:
1
2
3
4
5
6
7
8
9
10
Rup_flag
sl1
sl2
Where:
Unit
•Rup_flag
is a flag to activate the rupture definition
•0 = no rupture
•1 = rupture
Integer
No
•sl1
defines the point A of the following curve
Real
Length
•sl2
defines the point B of the following curve
Real
Length
Maxforce
Card 8:
1
2
3
4
5
6
7
8
9
10
K-tension
K-shear
K-torsion
K-flexion
Where:
Unit
•K-tension
is the stiffness in tension direction (1)
Real
Force/Length
•K-shear
is the stiffness in shear direction (2, 3)
Real
Force/Length
•K-torsion
is the stiffness in torsion direction (4)
Real
Torque/Radian
•K-flexion
is the stiffness in flexion direction (5, 6)
Real
Torque/Radian
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
# MCRASH DEFINITION FILE
#  UNIT : ms, N , mm, g
#   spotgap  max   aflag  lindat      length min      length max
           10.0       2       1           0.100            10.0
#searchgapfactor       doublegap         angle
            1.1             5.0            15.0
#    spring mass  spring inertia
        2.0E+00         2.0E+01
# nsfunc
     10
#      thickness           force
           0.60          5400.0
           0.80          7200.0
           1.00         10600.0
           1.25         13600.0
           1.50         18000.0
           1.75         21200.0
           2.00         25000.0
           2.50         32800.0
           3.00         42000.0
           3.50         54000.0
#    tens_factor
           0.33
# ractiv                     sl1             sl2
      0                    0.25            1.25
#       stension          sshear        storsion        sflexion
       100.e+03        500.e+03       5000.e+03       5000.e+03
# END OF MCRASH DEFINITION FILE
Go to
Main Module Environment File Description
