HyperCrash
Section Force
Section Force
Previous topic Next topic Expand/collapse all hidden text
Section Force
The file, $MCRASHDIR/section/sectiondef defines the parameters for the force and the Cut Approach sections.
Card 1:
1
2
3
4
5
6
7
8
9
10
Timestep
Filtering
Iframe
Where:
Unit
•Timestep
is the output frequency time for the root_nameSCO1 file.
Real
Time
•Filtering
is a coefficient for filtering (a < 1)
Real
No
•Iframe
is the default frame type (from RADIOSS 4.2 format).
Integer
No
hmtoggle_plus1Example
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
# SECTION DEFINITION FILE
#/UNIT/LENGTH/mm
#/UNIT/MASS/g
#/UNIT/TIME/ms
# 1. CUT APPROACH DEFINITIONS:
#       timestep       filtering          iframe
           1e-1          1.6500              12
# END OF SECTION DEFINITION FILE
Go to
Main Module Environment File Description
