HyperCrash
Option
Option
Option
In this directory are the necessary files to define specific user options.
To set and unset the option, the corresponding file has to be removed or the file needs to be renamed.
Renumbering
This option can:
•Renumber the part with the same ID as the property
•Renumber the nodes of each part from part_ID*10000 to part_ID*10000+9999
•Renumber the elements of each part from part_ID*10000 to part_ID*10000+9999
This option is activated with the file, $MCRASHDIR/option/renum_file which contains:
Card 1:
/RENUMBERING/WHERE/TYPE/FLAG/PART/OPTION
Where:
Unit
•RENUMBERING
is a keyword
Keyword
No
•WHERE
is a keyword which defined where the renumbering will appears:
•RENUM_IN_DTYPE: during the import of the file
•RENUM_ON_DTYPE: in the renumbering page
•RENUM_OUT_DTYPE: during the export of the file
Keyword
No
•TYPE
is a keyword which defined the type renumbering
•RENUM_PART_WITH_PROP_ID: the part will have the same ID as its property
•RENUM_NODE_W_PARTX1000: the nodes of each part from part_ID*10000 to part_ID*10000+9999
•RENUM_NODE_W_PARTX1000: the elements of each part from part_ID*10000 to part_ID*10000+9999
Keyword
No
•FLAG
is a keyword which defines:
•ON: the toggle button of the option is be activated by default
•OFF: the toggle button of the option is not activated by default
Keyword
No
•PART
is a keyword
Keyword
No
•OPTION
is a keyword which defined:
•RENUM_ALL: all entities defined in TYPE will be renumbered
•RENUM_NO_TYPE: nothing will be renumbered
Keyword
No
Card 2:
This card is necessary only if the option RENUM_ALL is used.
/TITLE/title_name
Where:
Unit
•TITLE
is a keyword
Keyword
No
•title_name
is the name of the option which will be displayed in HyperCrash.
String
No
Card 3:
/END
Where:
Unit
•END
Keyword to finish the input.
Keyword
No
License option
This option can release the license when the user does not answer a question during a defined time.
This option is activated with the file, $MCRASHDIR/option/license_opt which contains:
Card 1: (FLEXLM option format)
TIMEOUT feature time
Where:
Unit
•TIMEOUT
is a keyword
Keyword
No
•feature
is name of the feature to release after the time value
•MCRASH
Keyword
No
•time
is the time value in second
Real
Second
After the defined time value, the HyperCrash license is released and can be used by somebody else.
When the time value is exceeded and if the user wants to continue to use the HyperCrash, HyperCrash will request a new license to FLEXLM.  If there are no more licenses available, only the HyperCrash function "output” will be available to save the model.
Go to
Main Module Environment File Description
